So i've tried some overclocking
http://forums.amd.com/forum/messageview.cfm?catid=13&threadid=124355&enterthread=y
And failed cause I just had no clue what to do and the AMD forums weren't really a big help (though at some point i got 3800Mhz stable on 1 hour OCCT)
So I decided to set everything on default in bios and tried running prime95 and occt (just out of curiosity on a non OCed system)
Prime95 said FATAL ERROR on core 3 and stops that core after 5-7 minutes
OCCT stops and says error detected on core #0, or 2 (seems random)
what is going on? are these programms just off? Should I be concerned about this?
