[Solved] Need help with Phoenixminer settings.
I'm getting back into mining after about a 7-year hiatus (man how time flies) and I'm a bit foggy on how to set everything back up. So I have an Exodus and an Electrum wallet set up. I've downloaded Phoenixminer 5.5 for Windows and I'm confused about setting it up. Inside the folder are a config.txt, an epools.txt, and a dpools.txt. I don't plan on using dual pools so I know I don't need the dpools. What I would like to do is primarily mine ETH and send it to my Exodus wallet. I recall setting up multiple pools in a single config in case one wasn't online or something so we had secondary pools lined up. I would like to set-up nicehash as a secondary if that is still possible.
Could someone walk me through creating the batch file I need to configure Phoenix to mine ETH primarily and nicehash as a secondary? Oh, I'll be mining with an RTX 2070 in my main rig and I have an RTX 3070 to mine with too once this one is set up.
TIA
TIA
