It just Failed again with everything on stock settings.
8 Hours 9 minutes it said (Prime95 Application has stopped working)
A problem cause the program to stop working correctly. Windows will close the program and notify you if a solution is available.
It stopped on the first test 2100 Lucas-Lehmer iterations of M34230145 using FFT length 1792K
Windows didn't notify me!
Should I run the new Prime95 V28.9 or just RMA my CPU?
Run the new Prime95. I was looking at the version you were running and it is old and has bugs for the updated HT P4 and plenty of new updates for the new CPU's. I did not look through all the updates on the list V25.6 is from 2007.
