- Sep 17, 2012
- Pittsburgh, PA
Hi,
I was wondering if someone could help me out with OC'ing my sapphire HD7970 vapor x ? I would like to have this resolved soon so if it is a bad card I only have about a week left to send back to newegg. Stock clocks 1050/1500 at 0.947V idol - 1.150V under load. MVDDC 1.500V
My first issue is any time I increase the memory core I get screen flashing, along with the VDDC will increase from 0.947 to 1.246 while idol.
Next is if I use sapphire trixx to OC (any version) it will crash, my computer even with constant voltage enabled.
Trixx has my stock voltage set to 1.256V, but no matter where I set it with DLPS disabled along with constant voltage enabled my VDDC will drop much lower then where I have it set during activity(like 1.160V). Board Power Li is set to +20%, I have tried disabling and enabling CCC overdrive while using Trixx to OC with no change.
I have tried different drivers of CCC(13.4,13.5 ect) with no luck, also switched the bios on the card its self. I did clean installs/uninstalls of drivers.
I downloaded Afterburner and it had Voltage control lock even with me enabling it in the options. Did not crash my system like Trixx.
I had read that with AB you could change the MVDDC and thought maybe that would solve my issue with increasing the memory core but because it was locked for me I never got the chance to try it.
But I still do not understand why increasing the memory will increase the VDDC at idol but then still drop it during activity with constant voltage enabled and DLPS disabled.
Why can I get a pretty good OC on the GPU core but can't increase the GPU memory by 1 without the screen flashing and my VDDC increasing from 0.947V to 1.246V at idol then still dropping to around 1.150V at full load? no matter if I am using trixx or ccc to OC and that's with DLPS disabled along with constant voltage enabled in trixx.
As for settings using trixx to OC do I have it right, disable overdrive in ccc, disable dlps, enable constant voltage, +20% board power li, start at stock voltage 1.256V ?
Temps seem fine during stress testing, never goes above 71C with fans on auto.
My max OC without having issue so far is 1175/1500 at stock voltage 1.256V Board Power Li +20% (Still have the VDDC Drop during load)and I would like to know what I am doing wrong or is this a hardware/software issue ? My ASIC is 65.9%
System Specs -
Intel I5 3570K 4.5GHz
Asus Sabertooth Z77 MB
G Skill Sniper 16GB 1866MHz
Corsair HX750 power supply
Let me know if any more info is needed to help trouble shoot.
Any help would be greatly appreciated.
Thanks
System Specs -
Thanks
