need help with tricky partition format...
h0mersimps0n
Well, as expected Windows XP finally crapped the bed, had some corrupted file which made it freeze on boot (safe and non-safe mode).
I decided it best to do a clean install but I'm having an unusually difficult time converting and formatting the partition.
The setup is two 60Gig (120Gig total) on RAID 0, broken into a 20gig partition (the "C" drive - NTFS partition [logical]) and 90gig partition (the "D" drive FAT32 [extended]).
I have VERY valuable files on the D drive and don't want to mess it up.
Things I tried...
1.) windows xp boot disk - doesn't recognize the RAID hardware unless install is done from i386 folder copied from CD to the C drive (FAT32 only - which I haven't been able to achieve YET)
2.) ...using every disk utility on the ULTIMATE BOOT DISK CD with no avail- I tried to convert the NTFS to FAT32 so that I could use some other utilities to format it. All the FDISK utils don't recognize the correct size or won't convert properly.
3.) WIN98 boot disk + Partition magic 7.0 for DOS - crashes
So I exhausted every windows xp cd option, all the UBD CD options and my most hopefuly option the PM7.0 which crashed every time I tried it.
In one of the FDISK utilities on the UBD CD I managed to "convert" (use the term loosely) the NTFS to some FAT32 partition but it didn't convert it, it seemed only to change the "tag" for the FS.
BOTTOM LINE: The C drive is all kinds of miffed up from trying all the different fdisk variants and tools.
BOTTOM QUESTION: What is a good DOS partition program that's strong, and not likely to chew up my D drive while fixing and formatting the mess that is now my C partition?
Thanks
I think the problem is with the RAID array not being supported natively. Your best bet will be to just backup the data partition and use F6 to install the RAID drivers from a floppy when prompted in Windows install. Then you can format and install again on C:, and restore D: if it gets damaged.
