So ive just built this computer and it was running great, but when i upgraded the GPU from a 390x to a 980ti i started having a weird issue. i made sure to delete all amd filed and drivers and download the latest nvidia drivers. While i had my wifi card installed in the bottom pci slot the computer would freeze after loading into windows 10. when i remove the card it works fine. also, if it is installed in one of the pcie slots and i move the gpu from the top to the middle slot, the computer works fine. the only problem is when the gpu is in the middle slot it runs way too hot because the fans get starved of air. so im wondering if there is a way for me to get the wireless adapter working on the bottom pci slot.
Motherboard: Asus M5A99X EVO R2.0
Adapter:
TP Link AC1300 Wireless Dual Band PCI Express Adapter (Archer T6E)
Adapter:
