- Mar 6, 2002
- Monroe, Georgia
I would like to have 4 switches.
Switch 1: 1 Large Case Fan
Switch 2: 3 Small Antec Fans (used as case fans)
Switch 3: for an added Antec fan mounted on the MB Heatsink.
Switch 4: for an added Antec fan mounted on the video card Heatsink.
This is what I bought at Radio Shack...
4 Each:
Toggle Switch
275-612
SPST Submini
Contacts rated 3A at 125VAC/1A at 250VAC
4 Each:
Green Subminiature LED Indicator Lamps
276-069B
Absolute Maximum Ratings (25 C)
Power Dissipation: 100mW
Forward Current: 30mA
Optoelectrical Characteristics
Forward Voltage:
2.1V @ 20mA
Luminous Intensity:
2.5 mcd @ 10mA
Peak Wavelength: 565nm
Long lead is anode (+) connection
As you probably guessed, I would like to wire these LEDs into the circuit but I have minimal wiring experiece, so I willl need your help. I am not even sure the switches/LEDs combo will work.
I am good with a soldering iron, but will need your help on how to wire the on/off switches and LEDs.
All replys/suggestions welcome.
Thanks
4 Each:
Toggle Switch
275-612
SPST Submini
4 Each:
276-069B
Forward Voltage:
2.1V @ 20mA
Luminous Intensity:
2.5 mcd @ 10mA
Thanks
