Here are the 3D CAD models I have been working on this week, as a 2nd revision to my aluminum block (can be seen in the Waterblock Gallery Sticky).
-----I Want To Hear All Your Comments On This------
this one I want to make out of copper, with a thinner base.
base thickness .094" most of the time, down to .060" thinnest.
the thin base part occurs at the bottom of the 'dimples' in the base.
the height of the lower pillars is 1/4", the second tier is an additional 1/4". Any suggestions on changing those?
the orig. block was 1/8" x 1/8" channels/pillars, the new version is 1/16" x 1/16" (.0625" = ~ 1.6mm) Inlet will be 1/2" NPT with 5/8 ID hose barb (for my setup, anyway) and outlets will be 1/4" NPT with 3/8 ID hose barbs. Space is cramped.
Should flow just as good as my current block or better with drilled out NPT barbs
Surface area in the center 20mm x 20mm x 8mm high 'cube' is roughly 22.3 cm^2
Ratio of water to metal over the center (not including the base thickness) is 3:1 What is ideal ratio? I believe it is more metal though?
