- Nov 11, 2010
While I decide how to move forward from my 3950X and 5950X systems dying within a day or so of each other I'm getting by with my 5700G
While it's nice, it runs a little hotter than I'd like. With the stock heatsink in a 66°F room I see temps in the lower 60°C range while in a moderate work load. I'd like to lower that a bit so I am interested in replacing the stock cooler with something else.
I'm NOT looking to replace it with an AIO nor with a "tall" heat sink like a TRUE 120 type Air Cooler. This system will eventually be placed in my 3D printed case so I don't want something tall nor do I want to change the entire design to add a Radiator because there isn't one in the size/shape I need.
This being the case, I find myself quite a bit out of touch with what's available and what would suffice.
Does anyone have any experience with the stock-orientation (simple down-blowing like OEM) kind of cooler, and what would you recommend?
