I was going to order this stuff this morning. but instead I'm going to hold off for a day and see what you guys think. Maybe some other ideas that may yeild better results.
I have a P4 2.4c @ 3.4 with a heatpipe 101 and a vantec tornado 92mm, Abit AI7, 1 gig Gskill (pc4400), 6800GT@ultra speeds. Pcpower and cooling 425 psu. I currently run the following temps.
inside case: 80.6f
pwm temp: 86.0f
cpu: 109.4f
Now for the wc components that I want to get.
Rad: swiftech "hwlabs" pro II dual 120 "I got a below cost deal for a new one"
cpu: Swiftech mcw6000-P "I know this is a restrictive block"
pump: Fluid XP + Magnum Pump "conventional port"
res: 2x Danger Den filler ports. "I plan to put on on the top of the case and one on the bottom of the case, so when I purge the system, all I have to do is just uncap both and dump in distilled water to clean out the system and everything comes out the bottom of the case, instead of dealing with a resivoir"
coolant: Distilled water and water wetter
Hose's: 3/8" ID hose.
I'm not new to watercooling my rig. But I remember alot of people switching to 1/2ID instead of 3/8". I have always run 3/8" hose.
Just wondering if anyone see's a problem with this setup or has any other options to go with. I want that cpu block. and I will also be cooling my nb with my custom made maze block.
inside case: 80.6f
pwm temp: 86.0f
cpu: 109.4f
