Finally after 10 years my AMD build is finally failing and I need to buy a new pc.
For the past 4 years I have been doing the main work on my "trusty" Lenovo flex and the home PC was more of a relic sitting on my desk.
But as I don't really trust my Lenovo notebook, I want to buy a micro ATX build which will be used 90% for office work and coding and 10% for playing some old games.
My main requirement is a proper SSD M2 drive (970?) that will make things snappy and RAM which will be able to hold a LOT of open tabs.. (32 vs16)
As for the case I will buy a simple, black Micro ATX case from cooler master. with no LEDs!..
I will gladly take any suggestions about what CPU should I go for (I7 or I5?) And which Chipset I should buy on the Motherboard?
I was using AMD for the past 10 years and I am not feeling of buying AMD again.
For GPU I am using 1050TI and for now I will keep it.
Thank you all in advanced
