I've recently set up a watercooling system in my computer consisting of an MCP350 pump, Black Ice radiator, 5.25 Bay Res, Swiftech MCW6000K-64 waterblock, Danger Den Maze 4 GPU waterblock, 3/8 id ClearFlex tubing for most of the system.. I modded the pump to a 1/2 id inlet barb which made a huge difference in the performance of the pump. Between the radiator and pump I am running 1/2 id tubing due to the mod also I have an inline temp sensor between the radiator and pump. I am using a mix of Hyrdx and distilled water in the system.
I am running the circuit pump>CPU>GPU>Res>Rad mostly due to the convenience. I have the system installed in a CM Stacker with the radiator occupying the lower three bays as they are not in use, the pump is in the lower rear of the case, the bay res is at the very top bay. I have adequate ventilation, the stock 80mm on the top of the case for exhaust, the rear 120mm intake with the radiator set up to push through the radiator and vent out the front.. also I have the CM crossflow fan to provide fresh outside air to the motherboard. The CM has the 120mm fan that is on the hard drive cage plus my SATA drive has a cooler so I have.. a lot of fans you could say?
I chose these components mostly because I wanted to keep it minimalist, no huge noisy pumps, giant radiators that required outside mounting or making holes etc.
My idle temps are around 32-32-34 (CPU-PWMIC-SYS) with loads 38-38-38. I have an overclocked s939 3000+ @ 2.5 running 1.46V to the core and 2.5 to the memory. I am not overvolting the components other than the CPU but even that is not considered high by most standards.
Hopefully that provided enough information to get my to my actual problem..
I swapped out my ATI x800XL for a Sapphire x800GTO2 for the sole purpose of overclocking the @#^% out of it. So far, so good.. but that has caused me the new headache that my temps have gone to hell. My inline temp is telling me 30c going into the pump but my idle and load temps are up 3~5 deg. Last night while running ATI Tool to get my max core/mem I watched my temps peak at 41-40-40 which is nasty hot I think. My temps going into the pump are still in the 30~33c range. I know the added heat being created by the overclocked card have come into play.. the XL card did not require the 12v pci-e where this one does. All this added heat is bad.. the case temps are still fine, I have it cracked open to keep an eye on things as I am anal about all this.
I would really appreciate some help, comments, concerns.. suggestions. I am open to suggestions. I don't want to scrap the whole system and start over but I am willing to make changes to alleviate the situation. I am not counting nickels here so feel free to make suggestions. I am already contemplating a larger radiator, mounting it to the bottom of the case as I have room for a hamster cage down there. It's just the low noise, low impact would be sacrificed. The pump runs like a champ after that mod, I compared them side by side, I have two and it is like a garden hose barely open to a fire hose on full bore, I can wash my car with that damn thing.
Thanks much guys!!
~d
Thanks much guys!!
~d
