- Apr 10, 2001
I'm trying to find out how far apart the holes are around the socket on socket A boards. The holes that are designed to hold a heatsink are the ones I'm referring to. I measured 2.5" wide by 1.5 inches down. Is this correct?
Also, I'd like to know the amount of force in pounds that AMD recommends a heatsink to be applied with. I think I read 20 was sufficient, but I want to know what it is for sure.
Thanks in advance.
Thanks in advance.
