- Jan 8, 2002
- Boulder CO
i bought a 35000rpm dremel that you plug into the wall and i think that i set it up correctly for cutting a case. There was not that much detail in the manual so i am essentially asking if i put the sucker together correctly. Also, i purchased a cut off wheel kit and it came with all types of cut off wheels. Some being heavy duty wheels, some being normal wheels, and then i got a bunch of random big ones. Which ones are best for case cutting.
Also, any tips on how to go and use a dremel will be appreciated. i am going to go and test one out tonight on my old pentium 133 desktop case.
