- Jul 7, 2012
Hi ive a lian li pc70/75 with window.
Will be running for now Asus Rampage formula with Q6600 Go cpu standard atmo With 8 gig of Corsair domminator 1066 ram.HIS IceQ 6870 vid card turned up abit with amd overdrive thing.C&D drives WD velociraptors.
My PSU ive got for it is an Enermax Revolution 1050 watt.
Later im thinking of adding GPU into loop as thinking of later up moving to better GPU.
Need some feedback/pointers on specs ive sort of decided on?
So far ive an Aquacool cpu cuplex XT/di? blocks one could be older one as other looks like fluid goes through sort of in round and up.
Have a vanilla laing dc5 pump? varible one.
EK spin dual bay res got new cheap!
Going with 1/2" barbs so far.
The other bits ive looked to are.
Alphacool monsta Full copper 480 rad 80mm thick one. sort of just enough room to shoehorn under lid.but does take out my top 2 bays really.
Looking for fans for it have few delta PFC's so was looking to go with them? that takes rad thickness to 120mmish.
Was just going with push blow so fans underneath should i go with a shroud for them?as found a pulse modding for 480's 30mm thick.
Or if i can't squeeze in above PSU could go with singles or triple one and have last one without?. But that's if you think i need to use.
What other bits would you say i needed for rad install?
They do a neoprene gasket to go between rad and case.
Other way i looked at was going with a Koolance shroud that makes rad sit more or less almost outside case(more for thinner rads)
I do have few idea's 360 instead of 480? or whatever you thinks a better rad?.
The other idea i had was to go with the 9X120/140 panel rads and mount to passenger side of pc case? cut holes in panel or square hole so fans sort of cross vent case (have to make so some slack in tubing so can just slide bit forward if need to get in that side?
When rang place myside/uk. said about it to them they didnt recommend it on side as not very good/efficient? I can't see why it wouldn't be as good a 480 at top as to me surface area to thickness surface should be better pro rata as 80mm halved is 40mm x is 960 approx.
Where as other rad has an extra 120 fan.
Something like the Phyobia ones.
Be interesting with idea's/thoughts on this one versus other?
Also what fans would you suggest?
As with either of those rads it won't have too much to do for now.
As ive single 120mm rad (Ali/dellianware one) with a delta pfc using Zalman fan mate1(delta run butt upwards turn controller up fans slows down)
So use on pink/purple colour led 75%?ish as im writing this most cores @20 oC had max in game in summer around 50oC.
Pipe work and anti algae i can get from them(silver coil?)
would you go with any colouring/fancy liquids/UV reactive stuff? ive 5 liters of distilled water already.
My other thought was with EK spin res that would have to be in 4th/5th bays as rad/fans just encroach down to 3rd bay.
So that was why i was thinking of shroud/cover to lift up/out of case.
The other thing ive planned is to mount one or two fans in base to blow under GPU so also blow over mobo to keep temps down on that as many forget/neglect to think about mobo parts.as no side vents/fans to cover that area as is.
As the PC70 is a bit asthmatic in puff area with only 2 80mm Adda fans front and 2 rear.
One thing i did find was a converter shroud on flea bay where can use a 120mm fan over an 80mm hole(like a tapered funnel)
So going to make some custom feet for case as plastic turn out ones are poo plus not sure if fan could fit inside below mobo or put underneath with magnetic filters so can flip off as don't want to be turning it upside down to clean filters as mounted that way will probably work just like a hoover?
But what i will do is sit case on top of my cabinet/drawer i made on top of a sheet of ali/stainless steel so draw cooler and clearer air instead of a wooden varnished surface.
I got the PC70 with most of the bits(slot covers for 3.25 and 5" bays(4 bays are the flip down fronts)It's in A1 condition For £25 so not to worried about cutting etc but also don't really want to ruin it as such a nice case.
Would also like to get a proper PWM controller that will fit in 3.25 bays like the one a couple have made on here as would prefer to be able to control top/bottom fans independently as fan mates ok but don't really fit in/look right sitting there.
So hope some of you can be of help. anyway many thanks in advance.
