Ok first of all here is my computer specs.
Abit KT7A-Raid
Thunderbird 1.2 ghz
512 mb sdram
Geforce2 MX400
Windows 2k Pro
I have always been using opengl since its usualy the fastest way to play games, but one day it just stopped working, no idea why. The game im usualy playing is half-life (or rather one of the mods for it, in this case CS), i started it as usual (hadnt changed anything since the last time it worked, no new drivers or anything) and it said that "this opengl mode is not supported by your videocard" , i was really puzzled so i tried reinstalling the drivers but that wouldnt work at all, same error. Then i tried using other version of the detonator drivers which i use, but that didnt help. I then formated my hd (last hope...) and reinstalled windows 2k pro, installed HL and CS and started it....and what do i see.... "this opengl mode is not supported by your videocard" , at this point i was more or less ****ed off, i even tried playing in Windows XP (secondary OS on my other HD) but same error there.
I then checked the opengl32.dll file in the windows/system32/ folder and i saw that the version was all wrong, instead of a new version of the file, it was version 5.0.2195.4709 , which ive heard is the default driver in windows (???) , i then tried copying a new version of the file there but seconds after i did that the file got "changed" back to the default one. Now why does it replace it with a version that doesnt even work???
please people...begging here...CS barely works in direct3d and who would want to play in software mode......help...
Abit KT7A-Raid
Thunderbird 1.2 ghz
512 mb sdram
Geforce2 MX400
Windows 2k Pro
