i dont know...as the guide says, you want the lowest value that is stable for whatever clockspeed in the end. What are stress test (small ftt) load temps? All tbis matters and....you guessed it.. is in the guide..ok well for 3.7ghz what voltage setting should i set my vcore to righty now its set to 3.8
im wondering just how many times you post the same voltage typo...3.8V would kill your chip. You've posted that half a dozen times or more already, lol! Lets get back to punctuation use and getting the right values posted.i turned on my pc for the first time today and it booted into stock settings and disabled the overclock
edit im testing my overclock at 3.25 volts on the vcore will report back in a bit
20 mins in blend and 20 mins in small FFTs at 3.25 volts on the vcore havent tested lower but so far its stable no errores
edit still having the reboot issue i left my pc turned off for over 3 hours and when i turned it back on it booted into windows with the stock cpu settings overclock disabled other bios settings remain unchanged its only the overclock settings that are affected
im wondering just how many times you post the same voltage typo...3.8V would kill your chip. Yoyve posted that half a dozen times or more already, lol! Lets get back to punctuation use and getting the riggt values posted.
Did you get that cmos battery yet??? Repeating the same problem without applying a possible solution doesnt help anyone.![]()
still waiting on the cmos batter as for temps 53c for both ffts and blend voltage is 3.25 as set by me in the bios any lower and the system wont boot
Steps for overclocking the Core2Duos:
1. Remove from motherboard.
2. Throw in trash.
3. Buy an 7600k.
Seriously, the only thing Core2Duos kill at anymore is browsing YouTube. Those chips are ancient.
she glossed over my mention of it and did it again..Your CPU voltage cannot possibly be at 3.25v. It would kill your chip instantly, and I don't think it's even possible for you to set the voltage that high.
You must mean 1.325v???
10-4... let us know.still waiting on the cmos batter as for temps 53c for both ffts and blend voltage is 3.25 as set by me in the bios any lower and the system wont boot
Yes, I saw that too. Thought I would try to help hammer your point home. Don't know if it will have the desired effect though, or if he or she will even read it.she glossed over my mention of it and did it again..![]()
cmos battery installed stable at 3.71GHz at a manual 1.325 Vcore in the bios anything higher then 3.71 and it wont boot so im happy all memory settings are on auto
very likely. If you are able, you can add voltage or raise timings.Your limiting factor in this situation is the bios not having tools to allow you to downclock the frequency of the memory bus.
2. Throw in trash.
3. Buy an 7600k.
Is this for real? hehe
You can play the games, sure, however, you are putting a pretty low glass ceiling on things using such an old processor with only two cores/threads. PLenty of info on that at techreport.com...
..for example: http://www.techspot.com/review/734-battlefield-4-benchmarks/page6.html
Look how the Ph II x6 does with a slightly slower clock compared to the Ph II x2 with 200 Mhz more.... then look at the x3 above the x2... slower clock, on more core and WAY more FPS....
Again, for MOST games you can play it (though there are a couple that WILL NOT WORK with a dual core, you need more than 2 threads), so, yes.. playable, but long in the tooth in many cases.![]()
