- Mar 26, 2008
- Northern NJ
Greetings all. I hope this is the correct place to post this question. I have tried to ask this question on another forum and didn't really receive that much help. Long story short I am build a new desktop for my current desk. It is going to remove all the unneeded shelving that you typically find on a standard store bought desk.
It is a corner desk with nothing on it except a monitor stand that will go all the way back into the corner of the wall and stick out 22 inches from the wall out. The stand stick out like a V (if the bottom part of the V is the corner of the wall).
Here's what I am trying to figure out how to do. I'd like to mount a "floating drawer" in the center of this stand. The catch is, there is no place to mount the drawer except to the bottom of the stand. There will be no side mounts available. The entire mount will need to be able to be suspended by the one piece of wood that is the shelf above it.
The goal, create a "floating drawer" that will conceal a 15 inch LCD screen. So that when it is opened the monitor will lay on the desk in a a "\" fashion. I have drawn some pretty bad paint sketches as to what I am looking to do. Any help would be appreciated.
Note the desktop is already cut and finished. This is sort of a afterthought since I have a 15 inch LCD laying around I figure I'd put it to good use. It's a old LCD so it doesn't match my Dell WS. I'd much rather it be hidden and have the ability to "pull out as needed". I plan to use this as a media controlling monitor + a place to toss the indicators for software like CoreTemp among others.
Regards in Advance,
-Evo-
Regards in Advance,
-Evo-
