- Feb 25, 2013
- Spring Hill, Florida
Hello everyone -
I could use your assistance. I am trying to brainstorm a pc build that will be used strictly for streaming.
My current setup is - console or pc > capture card > MacBook Pro M3
After tinkering around with the settings for OBS my current setup is
Streaming - X264 @ 2560x1440 - 10k bitrate
Streaming (vertical) X264 @ 1080x1920 - 6k bitrate
Recording Hardware Apple VT H264 @ 2560x1440 - 20k bitrate
I was struggling trying to find a balance of quality and performance. I had always assumed using a different encoder would be used for something like dedicated GPU for one and CPU for the other. It had never occurred to me (and I didn’t know it was possible) that one chipset can be split into two different encoders.
I am quite impressed with what the MacBook can do. However, I would like to start adding more scenes, sources and maybe upping the resolution to 4k.
Recording at 4k, main stream at 4k, and then a vertical stream at 1080p.
However, I do not know how much horse power that’s going to take.
My goal is to build a small itx case, air cooled. If possible just a beefy cpu. Unless a gpu is needed.
I’m looking at cases like the Fractal Ridge, Jonsbo N10… I’m actively researching trying to find a small, cool looking case that will allow good airflow.
My questions to you -
For what I am trying to achieve can I pull it off with just a higher end cpu? If so - what processor would you recommend? I would like to stick with AMD if possible.
If I do need a gpu what’s a smaller form factor gpu that’s not overkill? This pc will only be used for streaming, encoding.
In the event that this can be done with just the CPU will I be able to get away with an air cooler… If so - what kind of air cooler do you think? If I need a bigger air cooler I would expand my case research to larger cases.
I’m thinking (ideally)
ITX case (probably the ridge unless we need a larger cooler)
Air cooled
AMD processor (9800X3D??)
SFF PSU - Corsair SF750 (Overkill with the wattage but I am a big fan of this psu)
GPU… If needed - Can you recommend one in the AMD line up that can record at up to 4k, small form factor.
32GB ram (corsair vengeance)
Thank you for your time and input!
Air cooled
