Hi Folks
Got a z97 oc formula open box from newegg and trying to get it set up for some ram testing. Am running the board with my 6+GHz g3258 under water.
So far...set up xp and 7x86 without any real issues. Everything boots fine at default settings. Figure that I'll only shoot for running the cpu at 4GHz for now.
Everything seems ok at default except that xp is a little weird. To shutdown or reboot, I have to do it twice before the system starts to actually reboot/shutdown...doing it the first time doesn't do anything :/
Applied the settings in the below screenshots and now am experiencing multiple issues including:
- although there's no post error, the system only boots at 32x instead of 40x
- am unable to change the multi using the asrock oc tool nor on-board button. When/if I try to change the multi using the on-board tool, the system freezes immediately.
- tried a number of single psc sticks, can't get them running at default speed even with up to 1.85v (a single 2933 tridentx stick gets right into windows at 1467)
Is it me or the motherboard? Am I missing something? Do I have a setting wrong? These settings on the xpower ac were enough to get the cpu to 5GHz and psc at 2600/2666 without issues.
Tips, ideas, tricks, etc greatly appreciated!
