need some help!
Zerileous
Senior Member
are you planning to OC?
if so are you planning to push it hard or just up thje FSB a lil?
how much do you want to spend?
Right off the bat i would recomend the thermalright SLK-900 heatsink with a nice sunon fan, or if you dont care aobut noise, get a delta or vantec tornado.
SLK-900
High SFM and high volume sunon
More reasonable noise level, YS-Tech fan
i just pulled a few links off www.svcompucycle.com
They do a good job and have had noting but good orders from them, check around there are many good sites, this is just the one i usually go to. I can give you better answers when you answer my questions, this is just aobut top of the line.
W
Wolfeinstein
Disabled
CA
schismspeak
I'm now in Colorado
Wolfeinstein said:
first thanks for your help.
Second i haven't oc'd yet i want to but i still don't know much about it yet i'm looking for good sites that can teach me.
i will like to get good results not push it where i burn my cpu or my mem. i have athlon 2000+ 512 corsair cooler master hsc-v62 this fan, would this be ok for oc-ing?
http://www.coolermaster.com.hk/product_detail.asp?lang=eng&at=boutique&category_id=1&product_id=7
slk-900 seems pretty damn expensive.
to answer your question that cooler will do fine for moderate overclocking.
W
Wolfeinstein
Disabled
CA
wow thanks a lot this really helped!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
do you know how much my agp frequency should be?i'm using ati 9700 pro card,athlon 2000+
thanks again
N
nerdlogic
Guest
Keep your AGP bus as low as possible. Depending on your board, you may be able to get the 1/5 divider.
SiliconX
Out of the Light
The SLK-900 seems to be the HSF of choice for air-clockers. I've seen nothing but great results for it.
Yeah, it's expensive. But IMO, it's worth it for the peace of mind you bought a great cooler for your processor
bill
Wolfeinstein said:
nerd thanks i have asus a7n8x mb you mean like at 66 mhz? or just set it to auto?
I keep it between 66 & 70 . 66 for reg use & 68-70 for benchmarking. i've some go 100 but i dont think it's worth the risk of frying the card or the agp slot , but thats just me.
