Need some opinions!!!!
Tat
Ok guyz... I have only about $100 ( => unemployment :( ) to upgrade my dam old G2.
What is the best video card that I can posibly to get out of it?
Yes, I'm planing to OC as much as I can because I'm running sweet rite now on my XP-M :thup:.
Thanks.
There some cheap radeon9500 pros on ebay. I suggest you get something in the range of 9500Pro or 9600Pro or higher, anything else would be just extremely underpowered..
First, thanks for the fast helping :)
I have done some reseach it said that non-pro 9500 is good rite? But it is hard to find.
But anyway, Is there any specific brand good for overclockin? Or anything to dedicate good for OC?
Thanks.
Guyzz.
If I can get a Sapphire 9600XT 128MB DDR for under $100. Is that good? And that card will be good for OC rite?
the 9600xt is a good low/mid range card. probably the best you'll find for just around $100..... unless of course you have a hook-up.
The SE's usually have a 128bit memory interface that is not a good thing...Stay away from any of the SE cards if possible.
