need some tips o/c'n A64
LBJGH
North of Toronto
:clap: Hey guys, I finally got my A64 system up and running last night. :clap:
Below are the components that I'm running:
AMD 3100+ 1.8ghz, 1mb (identified as 2900+ by the motherboard)
Epox 8KDA3+ (bios 06/15/2004)
Corsair XMS/OCZ PC2700 at cas 2.0 1t 3,7,3
Thermalright SLK948U
I did a quick o/c last night and was able to hit 2258mhz (respectable 458mhz overclock) but not 100% stable.
I'm just wondering if anyone has some tips to squeeze the top o/c out of my stuff. The memory has run up to 215mhz with looser timings.
The Epox motherboard has:
1x, 2x, 3x, 4x, 5x HT
bus (fsb) overclocking up to 350mhz
no multiplier adjustment
AGP/PCI lock
lots of voltage settings
Are there any windows-based applications to adjust the multipliers (lower than stock) and system voltages? I figured someone would write and app for tweaking A64’s using AMD’s cool’n’quiet technology.
Links or tips appreciated.
Tx LBJGH
Clockgen works for my A64. Just set your HT to 201. You can adjust multi's, voltage and HT speeds from windows, but not ram dividers. You have to do that in bios.
