- Aug 12, 2002
- Gettysburg, PA
Well sometime after Xmas I am upgrading and I want to make my machine over twice as good as what it is now. (through 3dmark, I want about almost 3 times)
So here is what I plan on getting...
Gigabyte GA-7VAXP-----------------------------------------$113
Lite On 48x24x48 CDRW-----------------------------------$57
CORSAIR MEMORY XMS 512MB PC-3200 Cas 2.5------$199
Gigabyte GV-R9700PRO RADEON 9700 PRO------------$350
And also a 333FSB Athlon 2400+ (they are going to make those right, if not I guess 2700+)
So what do you think. All thist stuff stat wise is going to stay the same, the brands may change depending on what you suggest but I dont relaly want and/or need any more features. So this is pretty much what it will be except the prices will change by then.
Things want comments the most on are the RAM (I want PC-3200 and I want something good but is there anything cheaper and just as good).
Any help is appreciated, BTW the system I will be going up from is in the sig, and everything else is staying the same. Acctually the burner I will probalby get ASAP because I need my old burner for a new machine I am building sometime in the next 2 weeks.
