Need Some Volt Mod Help Please.
IntelRulzz
Alabama
Hey guys/gals. This is my first post here, so take it easy on me. Ok here is the question. I'm using a 2GHz P4 with the MSI Ultra 645 SIS chipset Motherboard. The highest vcore I can go is 1.6, well it only really reaches about 1.56. If anyone can help me out with volt modding this board, I would really appreciate it. I would like to get atleast 1.8 volts. I can only go to 112MHz bus speed and that is it due to the lack of voltage. Thanks for any help.
Later
batboy
Senior Moment
Kansas, USA
If this P-4 is a Northwood (sounds like it from the default voltage) and if you have good cooling, I can help you with wire wrapping the VID pins on the CPU. You'll need to have good cooling first though.
I
IntelRulzz
Alabama
Hey thanks. Yes it is a northwood. I would really prefere to volt mod my board though. I've allready seen an article on wire wrapping the cpu. I am using the stock HSF as of right now. My Volcano 7+ shoulc be here on Monday though. Thanks for the help.
I
IntelRulzz
Alabama
Well damnit. Someone told me to put it here. Well I'll move it again. Thanks for the help though.
