Need Suggestions for New SSD for ASUS Prime Z690-P WiFi
Crash1
Currently I have SAMSUNG 980 PRO SSD 2TB on my ASUS Prime Z690-P WiFi.
I am looking to get another for rebuilding W11 and to have a backup.
Any suggestions on something maybe a little cheaper and as good or better that will be compatible with the ASUS Prime Z690-P WiFi?
Thanks and for those in Debbie's path....be safe!
Here's a relatively recent thread asking the same thing. THere are several solid options there too.
Thanks EarthDog!
That heatsink looks huge! If I remember correctly the Samsung barely fit.....wonder if this will fit the ASUS Prime Z690-P WiFi?
It fits in mine.
So.....just to verify....YOU have the WD_BLACK 1TB SN850X NVMe Internal Gaming Solid State Drive with Heatsink (WDS100T2XHE) and it fits?
If not but you have another version (not the WDS100T2XHE), please let me know which one you got.....
Thanks!!!
Thanks!!!
No I have a Samsung 970 2 TB's
Well I will report back next week weather or not if it fits......just order one with the HS!
I forgot my case has a glass side so I glanced in and it appears that as long as the HS is no larger than the stick.....all should be good!
Will let you all know!
