need sum advice
warduck
I've got a be6-2 mobo. I just remove the greenie/mobo chipset heatsink. I found that the surface of the greenie was rough an there was no thermal grease. I'm told this is normal.
This is my question should I smooth the surface of the greenie an put articsilver on it an put it bak
or
I have a cut down p3 heatsink I made for a vid card. Should i use articsilver epoxy an glue this thing on there as its 3 times the surface area of the greenie.
I could put that on with or with out a fan.
Keep in mind I have a huge alpha cooler for the cpu blowing serious air on the mobo chipset.
what ya think I should do
I would recomend lapping the greenie and using a bit of AS on it but that should be enough, maybe if it is getting quite hot you could stick a 486 fan on it
Yeah, that should work well. But if your not using that other heatsink for anything, more power never hurt ;-)
First thing I did when I got my Soyo 6BA+III was to lap that "greenie".
Danm thing was nowhere NEAR flat....and of course, there was no thermal compound on it.
Lap it and put on the A.S.....
Mr B
