Need to find some 120mm Blue Boihazard or Radiation fan grills.
rataboo90
I've been looking everywhere, I'm talking about the ones like in the LEET SYSTEM thread. Plz help!
psionic98
just find one in aluminum in general and color them yourself.. it takes some time.. electricity and some chemicals.. but if you're really into customizing that would be a good way to do it!
Diggrr
Underwater Senior Member
That's what I'd do too...sort of.
Buy some nice laser cut grills, and color them with Duplicolor's Metalcast paint that makes them look anodized sapphire blue...adding more coats of the blue color layer can get a deeper color, all the way to a gorgeous cobalt blue.
Even the silver base coat is great by itself, having the most metal flake that I've seen in a silver paint.
I use their paint system all the time, and recommend it often!
Autozone carries it...
psionic98
well theres that option too! Old automotive guy here.. so anodizing was a fun side project, but the extra steps to buff etc probably takes more time than that paint would..good suggestion!
