Need Tyan S2460-WIN2K FAH info
Stanman
Vienna Virginia
Whats the best way to run FAH on the dual Tyan S2460 board with win2k? Do you use the -local or just use two folders for fah?
also what about running as a service? :)
SpeeDj
Senior Member
Milwaukee, WI
First off welcome back old friend, secondly create two folders, and make sure your shortcuts to FAH go in your startup folder and run them with the -local switch and then point your browser to team 32 and help out we need you! :)
J
Ebola
Senior Toilet Scrubber
Rosemount, MN
I just got a dually recently and this is what i did
1. set up two folders (fah1 and fah2)
2. name the clients different
FAH2Console-v219.EXE
FAH2Console-v219cpu2.EXE
3. make two shortcuts and use the local tag
"C:\Program Files\FAH1\FAH2Console-v219.EXE" -local
"C:\Program Files\FAH2\FAH2Console-v219cpu2.EXE" -local
and you should be set.
you can use the hideit program i have linked on the http://overclockers.ws page to hide the clients
Ploaf
Senior Member
Warren, OH
Glad to see you here Stanman.
The -local is not supposed to be necessary, but I think there are fewer problems when applying it. The client tried to use the registry when I didn't use it.
As for running as a service. A simple way to go may be to set it up as a never ending scheduled service. There are instructions for that here http://forum.oc-forums.com/vb/showthread.php?s=&threadid=60665&highlight=scheduled+task
I've done it and it seemed to work. An alternative would be to use firedaemon to set it up and I think you can still use the -local command with both options.
muddocktor
Retired
New Iberia, LA
Stanman,
I just wanted to step into your thread and say hi and welcome your visit back here. I started folding after you had left and I wondered who the guy that was leading in points of our team at the time was. I hope that you will come back and fold some more proteins with us and visit here in the forums with us.
Anyways, fold on, man!!
