need your approval
ashenfang
The Jet Man!
Indiana
I am building a computer for a friend for light gaming, and multimedia sound video stuff. Just all around good solid computer. Tell me what you think.
Antec Performance Series II Mid Tower Case With 350W Power Supply,Model:SX835II,Retail.
Specifications:
Case Type: Mid-Tower
Color: White
Material: 1.0 SECC
Drive Bays: 3x5.25'',5x3.5''
Expansion Slots: 7
Front Ports: USB2.0 x2,IEEE1394 x1
Power Supply: 350W(SL350)SmartPower
Cooling System: 80mm Fan Rear(Standard) x2,Front(Optional) x2,Sidepanel(Optional) x1
Mainboard Compatibility: Standard ATX
Dimensions: 20.6''x8.1''x18.6''(440x206x472mm)
Special Features: Removable Side Panels and Cages for 3.5'' drives. more info-> N82E16811129119 $82.00 $82.00
ABIT nForce2 Ultra 400 Chipset Motherboard for AMD Socket A CPU, Model "NF7-S" -RETAIL
Specifications:
Supported CPU: AMD K7 Duron/Athlon/Athlon XP Processors
Chipset: NVIDIA nForce2 Ultra 400 + MCP-T
FSB: 266/333/400MHz
RAM: 3x DIMM for Max 3GB DDR333/266/200,2x DIMM for Max 2GB DDR400
IDE: 2x UltraDMA 33/66/100/133 up to 4 Devices
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2xPS2,2xCOM,1xLPT,SPDIF Out,6xUSB2.0(Rear 2),2xIEEE1394a header,Audio Ports
Onboard Audio: SoundStorm APU(Dolby 5.1) + 6-Channel AC97 CODEC
Onboard LAN: 10/100Mbps Fast Ethernet
Onboard SATA/RAID: 2x Serial ATA, RAID 0
Onboard 1394: 2 Ports by Cable(See pics)
Form Factor: ATX more info-> N82E16813127166 $101.99 $101.99
SAPPHIRE RADEON 9600 Video Card, 128MB DDR, 128-bit, DVI/TV-Out, 8X AGP - BULK
Specifications:
Chipset/Core Speed: RADEON 9600/325MHz
Memory/Effective Speed: 128MB DDR/400MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 1 Cable, Driver CD
Max Resolution@32bit Color: 2048X1536@85Hz more info-> N82E16814102305 $113.00 $113.00
AMD Athlon XP 2800+ "Barton", 333MHz FSB, 512K Cache Processor - OEM
Specification
Model: AMD Athlon XP 2800+
Core: Barton
Operating Frequency: 2.08GHz
FSB: 333MHz
Cache: L1/64K+64K; L2/512K
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: OEM (Processor only) more info-> N82E16819103376 $137.00 $137.00
Kingston ValueRAM Dual Kits 184 Pin 512MB(256MBx2) DDR PC-3200
Specification
Manufacturer: Kingston
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 3
Support Voltage: 2.6V
Bandwidth: 3.2GB/s
Organization: two 32M x 64 -Bit
Warranty: Lifetime more info-> N82E16820141413 $87.00 $87.00
SONY MPF920 Beige 1.44MB 3.5INCH Floppy Disk Drive, OEM
Specifications:
Capacity: 1.44MB
Average Access Time: not specified
Interface: 34 Pin Standard Floppy Connector
Form: 3.5 inch
Media Type: All Standard 1.44MB & 720KB 3.5 Floppy Diskettes
Features: Ideal for replacing older floppy drive, or adding a second drive
Remark: OEM more info-> N82E16821103109 $8.00 $8.00
Western Digital SpecialL Edition 120GB 7200RPM IDE Hard Drive, Model WD1200JB, OEM Drive Only
Specifications:
Capacity: 120GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA100
Features: High-performance with 8MB Buffer
Manufacturer Warranty: 3 years
Remark: OEM Drive Only more info-> N82E16822144118 $94.00 $94.00
Logitech Cordless Premium Desktop Optical Keyboard & Mouse USB/PS2 104keys --OEM
Specifications:
Interface: USB/PS2
Number Of Keys: 104 keys+7 function keys
Wireless Technology: RF
Palm Rest: detachable
Design Style: standard
Mouse included: wireless optical wheel
Features: Corded Internet Keyboard, Cordless Optical Mouse, 7 Hot Keys, Integrated Cordless Receiver, Soft Touch Keys more info-> N82E16823126136 $29.00 $29.00
SAMSUNG 170N-Ivory 17" TFT LCD Monitor –RETAIL
Specifications:
Panel Type: a-si TFT /TN LCD
Native Resolution: SXGA (1280 x 1024)
Pixel Pitch: 0.264mm
Brightness: 270cd/m2
Contrast Ratio: 450 : 1
Response Time: 25ms
View Angle(Horizontal/Vertical): 150° / 120°
Input Connectors: Analog 15-pin D-sub
Synchronization Range: Horizontal: 30-81kHz, Vertical: 56-75Hz
Dimensions & Weight: 14.5" x 15.5" x 7.0"(WxHxD) / 10.3 lbs.
Manufactory Warranty / Phone No.: 3 years on parts, labor and backlight / 1-800-726-7864
Dead Pixels Policy: Replacement or Refund for 8 or more DEAD PIXELS ONLY! more info-> N82E16824001106 $435.00 $435.00
US Robotics 56K V.90 Data/Fax/Voice Modem, Model 2976 - OEM
Specifications:
Interface: PCI Bus, Plug and Play
Standards: V.90 and earlier ITU standards
Chipset: 3Com
DTE Rate: 115200 bps maximum
Fax Speed: 14400bps more info-> N82E16825104119 $38.00 $38.00
Lite On 52X CD-ROM, Model LTN-526, Retail
Specifications:
Read Speed: 52X CD-ROM
Interface: E-IDE/ATAPI
Buffer: 128KB
Access Time: 80ms typical
Data Transfer Rate: 3300 ~ 7800KB/sec ( Average : 5700KB/sec )
Features: Innovated SMART-X to get the fastest CD-DAE / VCD data extraction speed by request
Remark: Retail box (see pictures for details) more info-> N82E16827101201 $16.00 $16.00
Lite On DVD-RW/+RW Drive, Model LDW-811S, Retail
Specifications:
Write Speed: 8X DVD+R, 4X DVD-R, 4X DVD+RW, 2X DVD-RW, 40X CD-R, 24X CD-RW
Read Speed: 40X CD-ROM, 12X DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows XP/2000/Me/98SE
Features: SMART-BURN avoiding Buffer Under Run error, VAS to reduce vibration & noise during recording & reading
Remark: Retail Box (see pictures for details) more info-> N82E16827106924 $143.00 $143.00
HP deskjet 3550 printer, 14 PPM, 2400 x 1200 DPI, Color/B&W
Specifications:
Printing Technology: HP Thermal Inkjet
Print Speed: 14 ppm black/10 ppm color
Print Resolution: 1200 x 1200 dpi black/2400 x 1200 dpi color
Number of Nozzles: Not Specified
Ink Palette: 4 color
Frameless Printing: NO
Automatic 2 Side Printing: NO
Cartridges: C8727AN/C8728AN
Connectivity: 1 USB
OS Support: Win 98/Me/2K/XP, Mac OS 9.1/OS X 10.1++
Dimensions(WxDxH): 16.6 x 9.6 x 7.75 in
Manufacturer Warranty: 1 Year more info-> N82E16828104264 $50.00 $50.00
►ON SALE!
Antec All Clear PRO 80mm 4 pin Fan for all 80mm Computer Case cooling requirements.
Specification:
Compatibility: Case
Dimensions: 80mm
Nominal Speed(RPM): 2600
Max Air Flow:(CFM): 34
Max Pressure: 0.12 inch H2O
Heat Sink Material: N/A
Rated Voltage: 12 VDC
Noise(dBA): 30
more info-> N82E16835129027 $5.50 $11.00
Microsoft Windows XP Professional with Service Pack SP1a - Full Version OEM Designed for reliability, security and privacy, high performance, and ease of use, the Windows XP operating system provides a host of benefits for business and home users. A clean and simple desktop, rock-solid reliability, and easy-to-use features that take advantage of the digital age all contribute to the value of Windows XP.
*Must be Purchased with Hardware!!* more info-> N82E16837102143 $139.00 $139.00
Light gaming? My rig is more than enough for gaming, and dosn't even compare with those kinda specs. It seems like it's gonna be a great machine, everyone loves NF7-S boards. Might wanna look for better RAM cheaper though, that price seems a bit high for only Kingston...
Definitely wait for more opinions though, since i'm just crazy. :p
Not that it isn't enough, but it seems like your skimping a little on the video card. Not too familiar with the newer Ati cards, but why not go with a pro?
I'd get a slighter slower processor and upgrade the video card, but thats just me.
-CPFitz-
moorcito said:
I'd go with a 2500+ or a 2600+. Either will overclock nicely, ie. 3200+ speeds, and you can save about $40-50.
Just what I was thinking. Use the extra cash to beef up the video a little.;)
-CPFitz-
Yep. Get the pro 9600 at least.
And I thought white cases went out like the black and white tv. I never see anyone with a white case anymore. Not only b/c of looks, it gets dirty too easy. At least get a black one man. :)
