- Sep 7, 2013
Can't believe this but, I actually need 16Gb of RAM now.
Having Minecraft open along side 7 chrome tabs and my other apps makes Windows kill chrome, Minecraft and the folding client to free up RAM even though the 2Gb swap file isn't 100% in use... Never used to. Ever since the SSD was installed and became my primary drive.
Anyways, browsing the egg these two catch my eye: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820104455 and http://www.newegg.ca/Product/Product.aspx?Item=N82E16820313699
They would match my white theme nicely but the timings leave something to be desired.
So the question here is: Are there any good 2x8Gb kits out there?
How well would the 2 I linked tighten in terms of timings?
Also, how well does the HyperX play with 1090t's? I know FX has a hard time...
I'm open to any speeds, honestly If I can run 1866's on this 1090t that would help bring up the bandwidth a bit.
