Hello,
Im needing help changing the fsb speed in my bios to 133. Im using Award bios and i dont have any tabs with anything like fsb. However i do have settings called CPU clock ratio (which is currently set at auto)
and CPU host/Sdram clock (which is set at default)
is it likely to be one of those ?
My cpu is running at 650 at 100 fsb
it is a P6c (Coppermine) Pentium 3 E 500-1.13 G
1.6-1.7 v (if that means anything)
My motherboard is a Microstar MS-6178 a copy of the manual is here http://www.msi.com.tw/support/manual/main.htm
if it helps
Any input would be apreciated,
Cheers
Stew
if it helps
Cheers
Stew
