- Dec 2, 2011
- ATI RADEON 5850 HD SLI
Sup everyone, First of all thank you for stopping in to check out my post and your input.
Im currently running an i7 920 (2.66ghz) on an X58A-UD3R F1 Rev.01 Mobo.
I currently have it over clocked to 3.8Ghz stable.
I am running two ATI Radeon 5850 HD SLI.
My current memory is 3x2gb triple channel OCZ (Pc3 12800 stock timings at [email protected] - OCZ3G1600LV6GK)
Windows 7 Ultimate.
Ok here are my specs. If anyone has any ideas on better voltage and also my goal is to get this stable at 4.0 or higher.
Oh also I have a corsair H70 hooked up in my Cooler Master Tower. Currently under load on Prime95 and Intel burn test my temps are 55c.
CPU Clock Ratio................................:19
CPU Frequency .....(Ghz)...................:3.80
Intel(R) Turbo Boost Tech.................:[Enabled]
CPU Cores Enabled...........................:[All]
CPU Multi Threading.........................:[Enabled]
CPU Enhanced Halt (C1E)..................:[Disabled]
C3/C6/C7 State Support...................:[Disabled]
CPU Thermal Monitor........................:[Enabled]
CPU EIST Function...........................:[Disabled]
Bi-Directional PROCHOT.....................:[Enabled]
Virtualization Technology...................:[Disabled]
Uncore & QPI Features [Press Enter]
QPI Clock Ratio*..............................:36
QPI Link Speed* ..............................(Ghz):7.20
Uncore Clock Ratio...........................:x16
Uncore Frequency.............................(Mhz):3200mhz
Isochronous Support........................:[Enabled]
Base Clock (BCLK) Control*................:[Enabled]
BCLK Frequency (Mhz)*.....................:200
PCI Exxpress Frequency (Mhz).............:101
CPU Clock Drive (mV).........................:700
PCI Express Clock Drive (mV)...............:700
CPU Clock Skew (ps)..........................:0
IOH Clock Skew (ps)...........................:0
Performance Enhance........................:[Extreme]
Extreme Memory Profile (X.M.P.)..........:[Disabled]
System Memory Multiplier (SPD)...........:x8
Memory Frequency (Mhz)....................:1066 1600
DRAM Timing Selectable (sPD) .............:[Quick]
Channel A, B, and C Standard Timing Control
Cas Latency Time...............................:9
tRCD................................................:9
tRP..................................................:9
tRAS................................................:24
Command Rate....................................1
(All sub-timings on Auto for all 3 channels)
LoadLine Calibration............................:[Level 1]
CPU Vcore........................................:1.27500v
QPI/VTT Voltage................................:1.280V
CPU PLL............................................: 1.84v
PCIE................................................:Normal
QPI PLL............................................:Normal
IOH Core..........................................:1.26v
ICH I/O............................................:Normal
ICH Core..........................................:Normal
DRAM Voltage...................................:1.66v (Pink Color)
DRAM Termination..............................:[0.83]
Ch-A Data Vref..................................:[0.83]
Ch-B Data Vref..................................:[0.83]
Ch-C Data VRef.................................:[0.83]
Ch-A Address Vref..............................:[0.83]
Ch-B Address Vref..............................:[0.83]
Ch-C Address VRef..............................:[0.83]
Any help is much appreciated, I am a noob at this so looking for your guys' experienced input. Thanks again!
Windows 7 Ultimate.
