Last March I purchased and installed a Netgear RAXE300 Router. Although I mostly forgot the reasons for replacing a previous five-year-old TP_Link router, the RAXE300 resolved the issues that drove me to do that. It provided excellent Wi-Fi coverage in my home, and I was very pleased with it until I recently checked my Internet speed and found, at best, I was only getting 950 Mbs/s on an Ethernet connected desktop when the Comcast service advertises 1200 Mb/s. It did not take much troubleshooting to discover I was able to consistently achieve over 1,400 Mb/s if I connected my desktop directly to the single 2.5 Gb/s port on the Comcast router. To my pleasant surprise, it even achieves this over a 50 ft run of cat 5e so I did not install the cat 8 cable I was planning on pulling. The RAXE300 only has Gb ports (although it does have a 2.5 G input). Obviously, 950 Mbs was the maximum achievable with the RAXE300. Thus, the new RS700S.
The RS700S gives me consistently outstanding reliable WiFi coverage. Even at a far corner of my home, with four intervening walls including a kitchen with big metal appliances, on 6 GHz, I get a reasonably strong signal, and I am able to achieve about 500 Mb/s or greater on my phone. I am easily and consistently able to achieve 1,400+ Mb/s on my desktop. It also solved a couple of other nagging problems I was never able to fix or even determine what to fix. Previously, my three Comcast TV set top boxes would not behave well if connected to a RAXE300 port; I had to feed them directly from the Comcast modem Gb ports so I could not put it into Bridge Mode (although its Wi-Fi was turned off). Feeding them now directly from a RS700S Gb port works fine so the Comcast box is now finally in bridge mode. Additionally, my printer previously gave the appearance of a completely dead Ethernet port, and I even very briefly considered replacing it because of this. With the RS700S, for reasons that completely elude me, the Ethernet connection to this printer came alive and works perfectly.
Based on less than a week with the RS700S I fully endorse it. I wanted to put this out there as it is a relatively expensive beast but, in my opinion, an excellent very well behaved and performing device, more than I can say about any of the previous routers I used. I was originally going to get the RS600 (consequentially less expensive) but, because of the number of IOT devices in my home, some of which I really need to depend on, I decided to go for the RS700S because my research indicated it has somewhat better Wi-Fi coverage than the RS600. I suspect the RS700S was an overkill for me but now everything appears to work fast and completely reliably so I have no regrets. Although my RS700S is in my laundry room, for those that would place it in, say a living room, aesthetically it is much more pleasing than the typical modem style that resembles the original stealth bomber with jagged lines and multiple antennas sticking up with funky red and blue colors. It is 11.5 inches high so it will not fit on a shelf if it does not have at least this spacing.
