I will do my best, some of what I type will be redundant, so ignore it if you have done those steps already...
On Start menu - click settings - control panel.
Double click on Network.
You need these 3 things besides your Network adapter.
1. Client for Microsoft Networks
2. TCP/IP
3. File and Printer sharing for Microsoft Networks
***anything else could cause trouble***
To Install them click add. You will see four items(Client, Adapter, Protocol, and Service)
You will find Client for Microsoft Networks under Client - Microsoft, TCP-IP under Protocols, and File and Printer sharing for Microsoft Networks under service. You have to add them one by one. After you see all of them in the box click OK. It will copy some files from your Windows 98SE installation CD. If it stops and asks to overwrite on newer versions, click no. After installing some files it will ask you to restart. You have to restart, love that Microsoft...
After that:
Click on the Identification Tab.
There are 3 fields here, Computer Name, Workgroup, and Computer Description, shorter is better, I use:
Computer Name: CAS1 and CAS2 for my two machines
Workgroup: WORKGROUP(must be the same on both machines)
Computer Description: NONE1 and NONE2(real creative)
After that click on the Configuation tab and on the File and Print Sharing button...
Make sure all the options are checked and click OK and Ok again to close Network Properties. Once again it will ask you to resart, do it...
You have to do this on both machines...
Once you have this done on both machines, then we need to setup sharing...
Pick a folder on each machine to share. Right click on it, then click Sharing...
In the Sharing Tab, click Shared As: then type in a name
do that on both machines...then once each machine has a shared folder(of course you could selct more later) then we have to establish how they see them...
Double click the Network Neighborhood icon on your desktop.
Click on Entire Network
Click on Workgroup name
Click on the name of a computer yuo want to connect to
If you want to look at the folder temorarily just click on it, if you want to share it permantly MAp the network drive.
To Map the drive right click on the folder and chose Map Network Drive.
Then assign a drive letter and also put the check in reconnect at logon.
Then to browse it go to my computer and you will see the new network drive...
This is the text book way to do this, we may have ot paly around with some setting in TCP/IP, but we might get licky, give thsi a shot.
I will be here all night if you need more help...
