- Mar 7, 2008
Mobo is Asus B650E-F. Woke up and turned on the system and... no network. Got on using wifi for now. It is built in into mobo and is an Intel I225-V rev 3.
Things I've tried:
Restart the system - no change
Reseat the cable on both PC and switch end - no change
Tried alternate port on switch - no change
Check BIOS, network adapter is enabled. Tried disabling it then re-enabling it again. No change.
In device manager, the device is NOT listed at all.
Things I haven't tried yet:
Different cable as I need to see if I have a spare long enough. If device is not appearing in Windows at all not sure this'll help.
Update bios? Shouldn't make a difference, but will try anyway. Latest bios is more for Zen 5 updates so I didn't bother before for my Zen 4 CPU.
Any other thoughts?
Mobo is still in warranty but I really don't want to be swapping it out just for that. If this can't be resolved I'll probably get another NIC instead.
Things I've tried:
Any other thoughts?
