network send failure...
JoJoMoJo
and it looks like it started over now? im using zonealarm pro and behind a linksys router.... i obtained the information without a glitch....im using ie explorer proxy now checked....i dont have a regualar proxy however on my isp. Just makeing sure this isnt going to fail again.
usually no worries if it fails a few times! either the serve is overloaded usually or might be down, but they get them up quickly. If it doens't send right away there is a 6 hour auto-send that will try later on.
FOLD ON
NAS
hawk646 said:
I've got some in stores too. what to do after 6 hours?
well the client should try every 6 hours to send, if you wish to not wait, like i do :) then use the -send all flag and it will attempt to send all the units in the queue.
go to start- run and launch the client with the flag...
ie.
"c:\folding\FAHconsole.exe" -send all
FOLD ON
NAS
