Hi,
I have been having some very strange network switch issues. I have a solid IT background of 14 years in total but i have to say this problem has stumped me for the time being. I installed a Micronet 24-Port switch into a business about 4 months ago and this has been working just fine until recently.
This switch connects at this stage 11 PC's, 1 Billion ADSL modem/Router and 1 network printer. When using this switch i cannot get any IP addresses from the router which is configured as a DHCP server. All the PC's on the LAN report low connectivity issues and never recieve an IP address. If i assign a static IP address to a PC i still cannot ping the router.
I have tried lots of different network cables, different ports on the switch and the router to no avail. If i connect a PC directly to the router as it has a four port switch built in the PC gets an IP address and connects to the internet etc. This confirms that the router is working fine. I also have an older 8 port switch and if i use this it also works ok. I have tried 3 different 24port switches now and none of them will work (these were also different brands) I have also tried another power outlet for the switch)
I should also add that the 3 24 port switches all tested ok at other locations.
I am at a loss now what to test.
Does anyone have any ideas on this bizare fault?
Please help
Kind Regards
Lawrence
Please help
Kind Regards
Lawrence
