- Dec 22, 2000
Check this oddball crap out. I cannot, under ANY circumstances, run it at the default of 10x133. NO voltage adjustments up or down help. RAM, it laughs. I was pulling my hair out wondering why my Win2k setup kept crashing with an error code 4. I tried everything! Finally I put it at 100x10 and it worked. It DOES post at default, but for some odd reason it seems the IDE channels wig out. At one point FDISK could not even see the damn drives to format them, but you could see the partitions by "view current partition" in FDISK. Booting from the cdrom, it would crash at a point when it was loading the install files, sometimes after a few seconds, sometimes after 20 or 30 seconds.
Now here it gets weirder.
I can't run anything HIGHER thatn 133 either, at least not stable. I had it at 130x10.5 for a bit but it is a crash monster regardless of higher or lower voltage settings. So now I finally got my "best stable" speed of 110x12 for a measly 1320mhz...not even at default speeds yet, much less bus speeds. At 110x12.5 it will BSOD by running Sandra or 3Dmark2001.
What the heck is going on here? It appears to be a bad chip! I can max the multiplier at 12.5 and as long as the cpu bus does not go over 110 it will run. It is not ram, this Kingmax ran fine at 146 CAS2 in my previous KT7 board. Even at CAS3 and lowest ram timings in BIOS this chip will crash/freeze loading windows!!! What the heck do I got, a remarked 200fsb 1.3?
