Proud to announce that I'm now posting this from Dual 2400's. Well, If you want to get technical, I'm posting from a 1700xp and a 2400 mp.
First off, temps. According to MBM, right now mine are at 46 and 49, although they fluctuate a few degrees up and down. Now they are at 45 and 47. 46 and 47. 44 and 47. 46 and 48. 45 and 47. Anyways, how do these temps look? They seem a little high to me, it seems like I was in the low 40's before, but it has been a while since I last was running two processors. I'm using AS Ceramica, and SLK-800's.
Second Question. Right now my voltage is at 1.7 or 1.75, can't remember. Is it possible to only give CPU2 its default voltage, or does it do this automatically, or is it even possible to run the cpus at differen't voltages?
I'll be back in a few with temps under load. I've got some dvd encoding to do.
-CPFitz-
edit: Been encoding for about 10 minutes now. MBM shows the temps at 51 and 52. According to it, they've been 55 at the highest. Am I okay?
-CPFitz-
