- Sep 17, 2002
- ohio
New 9700 heatsink mod!
here are some pictures of a how i modified a p4 heatsink to fit my 9700. before this mod, after ut2003 you could not keep your finger on the back of the chip as it would burn you. now im at 360mhz oc and i cant even get the damn thing to get warm. heatsink was machined to sit down onto the chip inside of the shim, it is held in place with loctite #384 thermal epoxy. memory is at 330mhz. i will be making ram sinks this weekend and pushing the ram a bit higher. the problem with the ram is that it isnt so much a heat issue as it is an issue of it just doesnt want to go too much higher by design.
http://pcelite.ws/images/rad10.jpg
http://pcelite.ws/images/rad8.jpg
http://pcelite.ws/images/rad9.jpg
http://pcelite.ws/images/rad1.jpg
http://pcelite.ws/images/rad2.jpg
http://pcelite.ws/images/rad3.jpg
http://service.madonion.com/servlet...ojectId=4928802
with 365 clock
http://service.madonion.com/servlet/Index?pageid=/orb/projectdetails&projectType=6&projectId=4932224
__________________
-->asus pt4533c
-->2.8 clocked @ 3150mhz
-->512 rambus
-->radeon 9700 pro w/heatsink mods and running 358/330mhz
with 365 clock
__________________
-->asus pt4533c
-->512 rambus
