- Dec 19, 2000
This is an alpha prototype called the Swiftykiller. No I don't hang out at places besides O/C I just spy on them.
Bender (Jul 19, 2001 08:38 p.m.):
Correct me if I am wrong but doesn't aluminum dissipate heat better than copper, but copper conducts heat better. It makes total sense since the copper base conducts the heat, spreads it out into the alu fins to lose the heat faster than copper. I am sure Alpha knows what they are doing. They have all copper heatsinks for other applications so I know they aren't afraid of the stuff.
William (Jul 20, 2001 03:18 a.m.):
a copper aluminum hybrid is key. Copper will distrubte the heat better, and aluminum will transfer it to the air better. I don't think a lot of the heatsinks using a delta on the socket are bad designs, the heat output requires either a monster hsf(Glaciator) or a delta to overclock it and keep it in a good temp range.
CalCoolage (Jul 20, 2001 09:08 a.m.):
So why do Swiftech and Alpha use copper bases and aluminum fins?
Assuming this is something besides poor contact:
What is the thermal contact resistance between aluminum and copper? Are there tables of these resistances? Why is there no thermal contact resistance.between air and copper?
inertia
Yes, there are tables for measurements taken at standard temp and pressure (STP = 25C 750mm Hg). Why do you assume there's no thermal contact resistance between air and copper? This question demonstrates how much knowlege you are lacking. I happen to have a degree in chemistry (entirely not necessary in this application, but it serves as qualification methinks) and can tell you how to determine the the contact resistance: 1) Measure the temp of the exhausted air 2) Measure the temp of the heatsink 3) subtract air temp from the heatsink temp and viola you've got the contact resistance for the specific conditions of your system (pressure is a function of the fan you're using.) This'll work for the aluminum pins and the copper base as well. When doing this, you should get as close to the junction of the two materials as possible. You'll find that while the air/copper or air/aluminum temps are significant, the copper/alum is minimal.
inertia (Jul 20, 2001 10:03 a.m.):
Why do you assume there's no thermal contact resistance between air and copper? .
