New "bigadv" rig shakedown
ihrsetrdr
Señor Senior Member
Close to the San Andreas Fault
I saved a pile of money by buying a C0 stepping i7 920, but am finding that overclocking is much more detail-intensive than running a D0 on the same model motherboard. I am using XP primarily to monitor temps under load, as I try to get this CO stepping i7 920 OC'd up, and the voltages as low as possible. LM-sensors don't seem to work for X58 motherboards, so I have to test/monitor in Windows. I still have some testing to do, hopefully can squeak out another couple hundred mhz and drop voltages just a little more...
current load-testing screeny
Bobnova
Senior Member
I can't imagine that someone hasn't written a sensor for 'em. They did the K10s, which LMsensors doesn't officially support.
deadlysyn
Folding Team Content Editor, Who Dolk'd my stars S
Stealing your megahurtz at night
If I had enough to even build one i7 rig, I would be happy. My rig does just fine for what I use it for, but it doesn't quite crank out as many PPD as I would like. I just switched back from pete_scout, so my average is sitting at 0 for the moment, but I should be getting back in track pretty soon.
NV
I spent a LONG time looking at trying to get lmsensors to detect my coretemps.... for me running 'sudo modprobe coretemp' on every boot up before 'sensors' does the trick. Honestly I don't even really understand what it does (I think I looked it up one time, but I didn't have a firm understanding of it). I'm kinda like that linux user that just googles every problem I encounter to death until I find a solution, even if I don't have a full understanding of what I'm doing.
But yeah, 'sudo modprobe coretemp' worked for me on my EVGA LE... just throwing that out there.
ihrsetrdr
ihrsetrdr
Señor Senior Member
Code:
[email protected]:~$ sudo modprobe coretemp
[email protected]:~$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0:      +70.0°C  (high = +80.0°C, crit = +100.0°C)
coretemp-isa-0001
Core 1:      +66.0°C  (high = +80.0°C, crit = +100.0°C)
coretemp-isa-0002
Core 2:      +67.0°C  (high = +80.0°C, crit = +100.0°C)
coretemp-isa-0003
Core 3:      +64.0°C  (high = +80.0°C, crit = +100.0°C)
coretemp-isa-0004
Core 4:      +70.0°C  (high = +80.0°C, crit = +100.0°C)
coretemp-isa-0005
Core 5:      +66.0°C  (high = +80.0°C, crit = +100.0°C)
coretemp-isa-0006
Core 6:      +67.0°C  (high = +80.0°C, crit = +100.0°C)
coretemp-isa-0007
Core 7:      +64.0°C  (high = +80.0°C, crit = +100.0°C)
Cool, worked for me too! :thup:
Edit: Those temp readings are very much in-line with the readings I was getting in Windows.
