NEW BIOS:A7N8X DLX 2.0 1005 final
P-nut
P-nut
Shannon,MS
No problems with it,but...
I was runnin my memory timings at 4,2,2,2t with the 1004 bios after I flashed to the 1005 bios I couldn't run my timings at that.Memtest gave me 200 errors on test 5,so I changed my timings to 5,3,3,2t and alls good now:D
Roadkill
Regina, SK Canada
Yeah, I found they firmed up the timing with the 1005.001 beta. That one corrupted my install though. :( 1005.002 worked and a suspect it's the same as this one just moved to offical status.
P-nut
P-nut
Shannon,MS
Well back to the 1004 bios.
I flashed to the new 1005 bios and had my ram timings at 5,3,3,2t,I ran memtest all nite and damn it!I got 2 errors in test 8!So screw the 1005 bios,I flashed back to the 1004 and set my timings back to 4,2,2,2t,with this setting I can run memtest with no errors.I just looked the new screen showin 400 mhz :(
JAW1973
winters
bios 1005
Ya what is up with the 1005.. i flashed to 1005 i don't know why.. thought newer is better.. put on the same settings and my memory benchmarked at 2770 in sis sandra... i was getting 3060 before i flashed.. i went back to 1003 which was what i had before and my memory bandwidth is still the same2770.. what the F... does anyone have an idea...
and no i don't have my saved bios before i flashed 1500...i thought i saved it but it ended up being not a valid file..
can anyone that has a clue ..email me at [email protected]
thanks
