- Jun 21, 2002
I'm looking for a decent deal on a 2TB boot drive. I'm putting this into a Gen3 system (in sig) and upgrading from M.2 sata - so speed is not important. I know to look for DRAM and TLC but not much else.
I'm also going to be enabling TPM and installing Win11 (doing this over the winter break so it doesn't interfere with classes). I don't necessarily need the drive NOW but my storage is on the full side and I will need to be re-installing Windows at some point (it's been the same install for over 5 years, so with 10 going EOL I might as well start fresh). I figure I might as well do them both at the same time. Also, my current boot drive (Crucial MX500) is down to 63% remaining.
I think the WD SN850x fits the bill at $125
Cheaper drives like the T-Force G50, WD SN770, Samsung 990and Corsair MP600 don't seem to have DRAM.
The Crucial T500 seems like overkill at $146
*gets on soap box* This is just a frustrating market because I shouldn't have to read reviews to find out if the drive has a cache or not, that should be a simple spec. If people want the optimum performance at a certain task, then reviews are appropriate, but if I just want a utilitarian component that meets a couple of simple specs, there shouldn't be all this smoke and mirrors.
p.s. Gen 3 1tb is going to stay in the second M.2 slot off the PCH, and the existing boot drive is either going into an internal sata enclosure or an external USB drive enclosure. I'm willing to change my strategy on this for a good reason.
