- Aug 11, 2013
Hi guys, I'm putting together a build for a friend. I'm looking for general advice regarding the components.
Do these components match the purpose of the PC?
Are these components compatible with each other?
Are these components good?
Would you suggest different components?
Any advice on what you would do differently would be greatly appreciated.
The PC will be mainly used for these tasks:
Email.
Web surfing.
Drawing in autocad and sketchup.
Running ms access based energy assessment programs.
Running thermal modelling programs.
Generally low graphics but high data crunching
Cheers guys!
I've attached the BB code for the build so far
YOUR BASKET
1 x AMD Piledriver FX-8 Eight Core 9370 Black Edition 4.40GHz (4.70GHz Turbo) (Socket AM3+) Processor - OEM £179.99
1 x Corsair Vengeance Blue 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (CMZ16GX3M4A1600C9B) £143.99
1 x Toshiba 2TB 7200RPM SATA 6GB/s 32MB Cache - OEM (DT01ACA200) HDD £68.99
1 x Kingston 60GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/60G) £47.99
1 x OcUK Crusade 550W Dual-Rail High Efficiency '80 Plus' Power Supply £43.99
1 x Gigabyte 78LMT-USB3 AMD 760G (Socket AM3+) DDR3 Motherboard £41.99
1 x Aerocool Qs-200 Lite Midi Tower Case - Black £34.99
2 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £14.99 (£29.98)
1 x Xigmatek 75 in 1 3.5" Internal Card Reader - (CPH-7SPNU-U01) £4.99
Total : £609.49 (includes shipping : £10.50).
Email.
Web surfing.
Cheers guys!
YOUR BASKET
