AS5 has to be replaced every some period of time (don't remember, a year or two) or it dries and simply starts to perform worse.
No it doesn't. It seems you overlooked earlier threads - specifically
#17 above.
If you can show us ANY TIM, CPU, GPU, cooler, computer, or motherboard maker, or any whitepaper that reports TIM must be replaced periodically, I would be very interested in reading it.
I'll say it again - if you "
need" the "
few" degrees a fresh application of TIM might provide to keep from crossing over thermal protection thresholds, then you have greater problems you need to deal with besides your TIM being a couple years old.
Your temps should already be well within the normal operating temperature range such that a few degrees of degradation does not put you at risk of getting near those thresholds.
It is important to remember it is the case's responsibility to provide a sufficient flow of cool air through the case for the components inside. The CPU cooler need only toss the CPUs heat into that air flow. And it is the user's responsibility to ensure the case cooling is properly configured to provide that proper flow.
As for curing times, that does not bother me a bit for several reasons. The two main are (1), curing typically only gives you a "
few" degrees better cooling. So again, if you "
need" those "
few" degrees, you have greater problems to deal with first, like ensuring your fans are spinning, you are not blocking air flow (good cable management) , or you have equipped the case with enough fans and they are all blowing in the correct direction.
(2) While time is a factor in curing, so is the number of heat-up/cool-down cycles the TIM goes through. And, at least on new builds, there typically are several before hard-core, extra demanding tasks, like gaming, are performed.
