So currently I'm waiting for my tax return to come in but that doesn't mean I can't start doing stuff.. This build will break down into 2 parts. The first part I finished last night which is remove the hardware out of the case I will be using for the new build.
So being a little on the law cash side right now .... I had limited options for Casing my current unit called "Haunter" However that didn't stop me.
What do I have hiding in a closet????
Ohh is that a Old School Antec P150 Case???!?!?!
why yes it is...
First step as with any kind of work is to remove the cover and peek inside.
Inside was a old Intel Socket 478 Board with a Pentium 4 2.8ghz CPU ...
That had to go .. so out it came. Also, The Power Supply was way substandard (Antec 350w) for the transplant so that was also removed and thrown away
so now what to do... No power supply is a problem .. so How about a new Thermaltake Smart 650w???
Now the Case is set up and clean.. time to start on transfering Haunter over to her new case.
Yuk .. Dust ... Well i has been over a year since last cleaning (long story)
So now comes the long task of removing everything and installing everything into the P120 case ...
Once Done, Didn't turn out bad. (I need to handle the cable management ... which I will do later , I had to get done so I could watch Walking Dead )
So My first project is done ... now next step will be to go through the other case and Clean everything so she will be ready for new parts in a few weeks Found a bad 120mm fan on the Elysium so that will be getting replaced as well .
why yes it is...
