- Sep 18, 2004
- Illinois
Hey guys, im new here, like all the info on the forums. Well, i will be buyin parts to build a computer for the first time and i wanted to see what you guys think of what i came up with.
also, i want to know if it will be a good oc'er? Do i need any changes? What kind of cooling should i get?
Ok, Here it is: $2,000 Max Budget, Still need a Monitor(will buy locally), need suggestions on a good one.
Intel Pentium 4/ 3.2E GHz 800MHz FSB, 1MB L2 Cache, Hyper Threading Technology - Retail(233)
http://www.newegg.com/app/ViewProductDesc.asp?description=19-116-172&depa=0
ASUS "P4C800-E DELUXE" i875P Chipset Motherboard for Intel Socket 478 CPU -RETAIL (179)
http://www.newegg.com/app/ViewProductDesc.asp?description=13-131-464&depa=0
Kingston HyperX (Dual Pack) 184 Pin 1GB(512MBx2) DDR PC-3200 (263)
http://www.newegg.com/app/ViewProductDesc.asp?description=20-144-114&depa=0
Antec 550 Watt Power Supply With 2 Fans 5.25 Control Panel, Model "TRUE CONTROL 550W" -RETAIL (110.5)
http://www.newegg.com/app/viewProductDesc.asp?description=17-103-922&depa=0
Lite-On 16X DVD-ROM, Model SOHD-167T Black, RETAIL (30)
http://www.newegg.com/app/ViewProductDesc.asp?description=27-131-119&depa=0
Pioneer Black DVD+RW/-RW Drive, Model DVR-108, OEM (89)
http://www.newegg.com/app/viewproductdesc.asp?description=27-129-157&DEPA=0
Seagate 160GB Barracuda 7200.7 7200RPM SATA Hard Drive, Model ST3160023AS, OEM (110)
http://www.newegg.com/app/ViewProductDesc.asp?description=22-148-018&depa=0
SAPPHIRE ATI RADEON 9800 PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -BULK -OEM (197)
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-268&depa=0
Creative Labs Sound Blaster Audigy2 ZS PCI Sound Card, Model "SB0350" -RETAIL (90)
http://www.newegg.com/app/ViewProductDesc.asp?description=29-102-162&depa=0
Logitech THX Certified Z-680 5.1 Speaker 500Watt Silver -RETAIL (242)
http://www.newegg.com/app/ViewProductDesc.asp?description=36-121-105&depa=0
Logitech Cordless MX Duo USB/ PS/2 104keys -RETAIL (76)
http://www.newegg.com/app/viewproductdesc.asp?description=23-126-124&DEPA=0
Thermaltake VA3000 Dream Tower Black Tsunami VA3000BWA ATX Case with Transparent X type side panel window -RETAIL (125)
http://www.newegg.com/app/ViewProductDesc.asp?description=11-133-132&depa=0
Microsoft Windows XP Home Edition with Service Pack SP1a - OEM (90)
http://www.newegg.com/app/ViewProductDesc.asp?description=37-102-141&depa=6
