- Jun 17, 2019
Hey all,
So I just finished putting my new build together and installed windows 10 using a Microsoft usb. Windows installed no problem and I got to the desktop. I shut down the pc and removed the usb from the pc. However, every time I boot up my pc it won’t boot directly to windows, it will instead boot to bios. I installed windows on my SSD and have the SSD in the first boot option but that’s not working. Only way for me to get back to windows is if I enter the boot options and select “windows boot manager” option. How do I fix this?
Also, I noticed that on startup and when I get to the American Megatrends screen it’s showing me and a CPU Fan error. I checked the motherboard and it’s plugged into the right spot. The cpu fan is also running fine. I did a google search thinking maybe this is preventing the pc from booting straight to windows so I changed the setting in bios for CPU fan from “n/a” to ignore and then saved changes and restarted but still didn’t boot to windows.
Here’s my build:
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor
Motherboard: Asus - ROG STRIX X470-F Gaming ATX AM4 Motherboard
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
Storage: Crucial - MX500 500 GB 2.5" SSD
GPU: EVGA - GeForce RTX 2070 8 GB Black
Thanks
Here’s my build:
Thanks
